Passive belt light
Rucus
Passive belt light
Post by Rucus » Mon Aug 14, 2023 2:52 pm
Hi, so doe's anyone have any info on this dash light and if its on what that means??? thanks to anyone that can help. I take it this has to do with the seat belts maybe :D
mikec(nz)
Post by mikec(nz) » Tue Aug 15, 2023 10:50 pm
Google is your friend "there should be a cord under the seat attached to the buckle and that usually gets run over by people adjusting there seat and it causes a bad wire"
Rucus
Post by Rucus » Thu Aug 17, 2023 11:44 am
Hey thanks. yes have googled it and really couldn't find much on it. But that helps a little more cause I did find out about the passive belt box under the passenger side dash but couldn't find it so I may be able to trace it back from the cable's of which you talk .Cheers.
Rucus
Post by Rucus » Thu Aug 17, 2023 11:46 am
and of course check those cable's first. Thanks mate.
