2007 Fairlady Z33 Version NISMO
Grunzter
Re: 2007 NISMO Fairlady Z (Z33)
Post by Grunzter » Fri Sep 24, 2021 5:22 pm
BRONZEE wrote: Thu Sep 23, 2021 5:05 pm
bernjean wrote: Thu Sep 02, 2021 12:03 pm Really like the red one. :D
Would have thought you'd be into the orange. :P I didn't realise the Nismo came in the orange, learned a Z fact today.
I could be wrong, but I understand the Orange was only a Japanese Nismo colour, and not available for the Nismo 350Z in the US. :)
Grunzter
Post by Grunzter » Sat Sep 25, 2021 6:12 pm
Today I managed to fit the rear wiper assembly.
I took the arm and motor from the 2nd hand hatch I brought.
I had to repaint that wiper arm to make it look pretty with Matt Black from Duplicolour.
The finish was closer to satin, so perfect.
The new wiper blade assembly was from WiperTech in Aussie. New is nice!
While the plastic was off, i decided to give the inside of the hatch a good clean.
Anyway happy with the result, and now have a working rear wiper.
I used a new rubber seal from Concept Z.
Post by bernjean » Mon Sep 27, 2021 1:55 pm
Certainly like the orange on the 260 but I do think in the pics that the 350 look really nice in red.
Grunzter
Post by Grunzter » Wed Nov 03, 2021 2:44 pm
Nismo got a younger sister...
2012 Z34 ST
Grunzter
Post by Grunzter » Wed Nov 03, 2021 4:09 pm
A new cosmetic change... managed to score a 380RS steering wheel.
Will swap it over tomorrow with luck.
Grunzter
Post by Grunzter » Thu Nov 04, 2021 6:00 pm
All fitted up!
Had a little training from a youtube video, as once you have done it its easy, but for the first time it seemed like a long path to follow...
Will keep the original wheel safe and sound for the future.
Grunzter
Post by Grunzter » Sat Aug 13, 2022 4:56 pm
A few little changes since the last post.
New slotted brake rotors all round and new pads, and new fluid.
New rear diff bushes all round. Apparently the OEM center bush was a mission to get out. (I got some pro's to do it!).
The diff got a make over whilst it was out, as well as new diff oil.
The rear also got new Nissan OEM hubs and wheel bearings.
Drives like new!
The Number plate was also changed to the correct shape JDM plate, though they still have not got the holes in the correct place, so had to drill new ones.
Post by bernjean » Mon Aug 15, 2022 2:27 pm
Really nice Grant. I personally the 350's will become collectible in time. but that is still 10 years away.
Grunzter
Post by Grunzter » Sun Nov 19, 2023 1:45 pm
I had to replace my radiator, so got a Koyorad unit.
[Japanese brand, but made in Indonesia]
Visually its very nice and fits like a glove. All factor mounting points were spot on.
The AC condenser and fans were easier to install than they were to remove from the original unit.
My original unit lasted 167,000 km.
It's the 36mm version, looks twice the size of the OEM unit.
Part Number: KV022140R (V2999), replaces OEM: # 21410EV00A for the VQ35HR only.
The little cooler is new and for the transmission.
Buzzed
Post by Buzzed » Sat Nov 25, 2023 7:45 am
Do you still have the centre console/cubby bits? I'm thinking seriously about replacing the Japanese satnav screen in mine for something vaguely useful, so I may be interested in buying it from you if you still have it. I've no idea what they're worth though.
Grunzter
Post by Grunzter » Tue Nov 28, 2023 7:30 pm
Buzzed wrote: Sat Nov 25, 2023 7:45 am Do you still have the centre console/cubby bits? I'm thinking seriously about replacing the Japanese satnav screen in mine for something vaguely useful, so I may be interested in buying it from you if you still have it. I've no idea what they're worth though.
I just PM'd you.
I will be keeping it now as will keep the car, but gave you some options. :)
Grunzter
Post by Grunzter » Sat Dec 09, 2023 1:56 pm
Just when I didn't have enough to do on the 280zx, thought a few more jobs is necessary.
Fitted the Works Bell (Japan) Z33 Column Shifter (paddle shifter) for a bit of fun.
Took it for a short test drive and it works a treat. It only works when you are in manual (tip-tronic) mode.
They attach to the column like the 370Z so don't turn with the wheel, this is so the original steering wheel with airbag can be retained.
Also got a stainless Y pipe and some HFC's which i'll try and fit this afternoon.
Grunzter
Post by Grunzter » Sat Dec 09, 2023 6:19 pm
Didn't get very far with the exhaust, as the original one is a bit rusted so could not get the flange undone at the headers.
Will wait a week or so and get it on a hoist in case the grinder needs to make an appearance.
I will also fit a new 3.5 ratio VLSD to give it a little more buzz over the stock 3.3 VLSD.
