I bought a 350Z engine and gearbox only for the gearbox so I've got the engine + performance bits that were attached to it for sale.
The engine is apparently a little smokey, it had some oil sitting in the plenum. It's missing the throttle body. It has no loom, throttle body, alternator, injectors or oil filter stud. There are bolts missing from the plenum (it had a spacer which was removed) and the sump needs to be resealed as that also had a spacer which has been removed. This engine was making 187rwkW.
The flywheel and clutch is still on it, I've never touched a dual mass flywheel before so I don't know if it's normal but this one feels loose to me.
I don't want to ship it so it's pick up only, I'm looking for around $800 for it.
2nd is a NWP 75mm upgraded throttle body kit, apparently this was good for 15kW? It can fit other VQ35DE engines, see the above website for compatibility. Has done very low K's. $450.
http://www.nwpengineering.com/Phenolic_ ... .html#BBTB
3rd is an AAM competition oil pan spacer., details are here: https://aamcompetition.com/i-4644836-aa ... pacer.html
Comes with all the bolts, needs a good clean before use. Picture is of a new one. $180
4th is a plenum spacer, I don't know what brand it is but it looks to be 1/4" thick water jet cut aluminium. Comes with the bolts and plastic spacers for under the plenum. $120?
