300zx twin turbo not running well
Hi all. Purchased a 300zx auto twin turbo recently which has a few issues. Firstly when I start off from stationary the car nearly stalls. Also, doesn't appear to be boosting properly. Have checked on line but there are so many things on these cars that it could be. Any help would be greatly appreciated. Cheerz.
Check the adjustment of the TPS, check for fault codes, likely a bad det sensor or harness, check operation of O2 sensors as they are good at causing a stumble off idle when they are bad.
Beyond that seek professional help sounds mean but it really isn't and a good proper tech will sort it in very little time with minimal costs.
