speed cut removal
speed cut removal
hi, have anyone done speed cut removal on their 350z?
And $1100 is expensive for a re-flash just to remove the limiter. I'd wait until you've installed all your intended mods (exhaust, intake, test pipes etc) and then go for a tune at NZEFI. They'll maximize your power gains and also remove the limiter.
Or buy Osiris and do it all yourself haha
2005 350Z ST money pit.
nz new ecu will not work on imported cars, in fact the ecu wont work in other nz new Z too because it is married to the car's anti-theft with unique code. you can get this redone at nissan but probably not a very wise option.
only way to go is getting a reflash like already mentioned, if you are after power then you should get some high flow cats or test pipes and then get the reflash.. removing cat and getting it tuned definitely makes good power from mid to top..!
i personally dont see much point in using aftermarket ecu in 350z, stock reflash will do everything you want.. for most people
tuner so i can fiddle with the ecu myself
i think standard doesnt allow you to use rom editor, which is needed to create your own rom, you basically tell uprev team what you have and they will create a generic map based on their database, and you can probably choose how you want ur rev/speed limit etc also, and they send you a rom file so you can reflash your car with it.
with tuner one you can adjust everything urself
thanks, I have try look it up. not much luck. can you sent me some link of it?OMSIN wrote:I did a google search for Osirus dealers/tuners in NZ, apparently there are a few shops around so you should just be able to pay a flat rate and have the local shop set it how you want it
