Servicing
Should be servicing your 350 every 10k.
From my owners manual; basically 45k, 50, 55, 60, 65k and 60k service are all the normal things that you should check with any service, change oil filter, replace oil, check for leaks. 70k lists, check diff oil, and it really does make a difference. Your Zed is probably on it's 2nd battery by now, or 3rd.
80k service is more detailed.
The joys. At least you're aware and keeping on top of things. There were a fair number of engines swapped out on the rev-ups to the long block under warranty. Your poor Z must have missed out.OMSIN wrote:Yea, typical rev up motor
One of my mates who works on Zeds said this is what he does to cure the infamous Rev-up oil burning;OMSIN wrote:Not sure if there is a fix, haven't been able to track down any relevant up to date threads where its mentioned
Bore out and fit oversized Wossner pistons and rings.
Swap out the valve seals and sometimes do some work to the valve guides.
A solution offered when manufacturers do not know whats wrong, hoping it was an assembly problem and not a design fault - obviously replacing the whole engine is overkill, but when you don't know whats wrong you cannot fix itBuster wrote:I always thought it was basically a ring problem and I assume entirely fixable but Nissan chose to fit replacement engines.
