350z clutch
350z clutch
I would like to get some advise on clutch replacement on a 350z
should I stay with duel mass flywheel or soild fly wheel
exedy have 2 options
many thanks
many thanks
I'd recomend staying with the Dual mass flywheel, I went the lightweight route and regret it for daily use. You may or may not be aware of the whirring noise that you hear around 1500rpm without the DMF. Personal prefernece at the end of the day.
Why do you regret it for daily use? My clutch is ok at the mo, but it had come to mind about when the time comes, I'd like a freer revving engine and thought about doing thisS13 Silvia wrote:I'd recomend staying with the Dual mass flywheel, I went the lightweight route and regret it for daily use. You may or may not be aware of the whirring noise that you hear around 1500rpm without the DMF. Personal prefernece at the end of the day.
Because of the noise around 1500rpm that you get due to having a SMF, It can get quite irritating, DMF gets rid of that vibration. For a weekend car that does mostly open road driving it's definitely worth considering as you won't be down in that rev range often. I'll see if I can find a youtube vid for you to get a better idea.bugjuice wrote:Why do you regret it for daily use? My clutch is ok at the mo, but it had come to mind about when the time comes, I'd like a freer revving engine and thought about doing thisS13 Silvia wrote:I'd recomend staying with the Dual mass flywheel, I went the lightweight route and regret it for daily use. You may or may not be aware of the whirring noise that you hear around 1500rpm without the DMF. Personal prefernece at the end of the day.
Note I am quite fussy, it may not really bother some people.
