European/ Nismo cam for Z31
Russ84NA
Post by Russ84NA » Sat Jan 27, 2007 4:39 am
I am installing new euro/nismo cams in reworked heads in my 84 NA Z31. The stock cams in the U.S. are 252/252 duration and .393 lift. The information of these cams is available in the FSM in the Engine Mechanical (EM) setion. There is a circular graph with values a thru f showing when the valves open and close. My understanding is that the stock cams in european Z31's is the 264/262 duration with the .393 lift. What I need is the graph and/ or a thru f values for those cams. If anyone has a FSM that shows them, would you be so kind as to send them to me or post them so I can get them.
Thanks.
I am after 200 to 250 RWHP out of an NA engine.
