front cv joint noise when I turn
When I turn left my car makes a noise EXACTLY like a worn out cv joint, (obviously a 280zx does not have front cvs) I have checked over the brakes and suspension as best I can but cannot seem to find any fault, it clicks faster with speed and under braking. The handling doesent seem to be effected in any way and the wheel bearings are relativly new, (I checked and re-packed anyway) if any one can help at all it would be appreciated, if anyone can identify the fault ill gladly post a voucher for a box of beer haha. Cheers
Have you checked the brake caliper is mounted nice and tight. If I am right then I will pm details for tje voucher.
Yea I thought that was it myself but not the case, it realy has me beat haha. Just going to drive it untill somthing develops.
maukuzed wrote:Thinking back i once had a car that did something like you are describing and it turned out to be the shim behind the brake pad , the holes where the locating pins go through was slopped out and moving back and forth under differing driving conditions
