Air filters for triples
chris'ntrish
Post by chris'ntrish » Sat Oct 05, 2013 9:12 am
I had a 'nearly nasty' experience with foam filter Ram Flo filters on my triple carb set up .i.e. ..backfire ... then fire!! Want to avoid a repeat. While K&N would be my preference, they don't seem to list any units for Dellorto DHLAs and pipercross only do twin set-ups I think so it's three separate units or ???? I'm hoping someone has knowledge of whether there is a 'universal' fit K&N or other filter system which has non-flammable filter material.
While an airbox would be an ideal solution, there's so little room to fit anything prefabricated that would 'flow'. All wisdom and experience welcome.
Post by Andy » Sat Oct 05, 2013 12:02 pm
Hopefully Nzeder will pipe up here, scuse the pun. :D I have seen in his possession a Nissan triple airbox with remote filter that would suit your restricted space. Work of OEM art.
big sam
Post by big sam » Sat Oct 05, 2013 7:23 pm
Might like to see that myself...
nzeder
Post by nzeder » Sat Oct 05, 2013 9:36 pm
All in due time guys. But what I have is very hens teeth and from a factor triple carb Prince/Nissan skyline + a 280z (USA spec S30) front air filter box feeding this rare part. And this setup does flow and has been dyno proven on a number of engines including a 3.1l race engine and make 10% more mid range over pod filter + custom airbox or vs open trumpets.
I will post more info later in my build thread.
