compression testing
compression testing
just checked the compression of the l28 and not looking good.
can anyone tell me when i put oil in the cylinder and checked compression again, is 10psi enough of a increase to say the valve seal or hot valve clearance could be an issue.
all 6 cylinders increased by at least 10psi cyl 4 by 30psi i can remember the engine rebuilder i used saying he had done the hot valve clearances but now im not so sure because the engine wasnt running when i picked it up. (needed dizzy spark plugs etc)
thanks nathan
thanks nathan
did the test again with throttle open got more even readings for all but cylinder 4 still sat at 135psi and same with oil
the rest of the cylinders were 155psi and 160psi with oil so not as bad as first thought but still bordering to low for cylinder 4
pretty sure manual says if lower than 128psi its rebuild time.
Well the engine I plan to use in the track car has 140psi on all cylinders I have been told. I guess I should test it sometime.
This is just to get the car going, later on I will be rebuilding another engine I have then I will just swap out over a day.
