I have one too many intake manifolds and need $$ to go towards a set of triples from another club member.
This manifold is new - never used and would cost over $900 land if you were to import your self today (they sell for $750 AUD = $1000NZD due to our poor exchange rate)
It comes with the idler shaft and intermediate shaft for fitting to the stock 240z/260z firewall pivot bush thing. Also on the idler shaft is a cable pull option. It comes with o-ring soft mounts and will require the purchaser to source drop links and correct length M8 studs/nuts for your setup. The price reflects the absent drop links that I am using on my already ported intake manifold.
Again this is brand new and not touched/ported it has 45mm bore at the carb end and 35mm at the intake which matches the stock port size on a L28 head. There is lots of alloy on this intake allowing for large porting if required which is not the case on a number of the cheaper intake manifolds that are available.
I will get some pics up later today of the actual item but here is a sample pic
Asking $500 PM if interested.
Mike
FS: New Japanese L6 Triple Intake Manifold
Pics of actual item
- PIC000015.jpg (1.84 MiB) Viewed 3698 times
- PIC000016.jpg (1.83 MiB) Viewed 3698 times
