Posted: Mon Jun 01, 2015 6:14 pm
While on the NZ Datsun Southern Cruise I started noticing a noise from the right rear especially while rolling at slow speed, thought I'd investigate it so I jacked up the car and ran it in gear and it looked like the brake caliper was moving in and out slightly. I pulled the wheel off and took the caliper off and oddly the brake pads are worn on a taper but top to bottom rather than left to right.
I had to space the caliper out when I put the Z31 rotors on it and it's possible the spacers were too small in the outside diameter which might be letting the caliper wobble a bit. I made some new caliper spacers on the mill that are much more substantial, bought some new brake pads too. Haven't quite got it back together yet but I'll do that over the next couple of days. I've got some new wheel bearings just in case I need to replace them.
I thought while it was sitting there I'd try and swap the engine mounts for the Castlemaine Rod Shop ones and urethane mounts with safety interlocks in them, the drivers side mount isn't very easy to get out and after getting it out and getting the new one in I found out they aren't going to work, they are made to sit the motor back about another 25mm and I can't do that as the plenum won't clear the clutch master cylinder. I'll use them on the white car instead.
