What turbo to put on an LD28
buddabeast
Post by buddabeast » Thu Feb 02, 2012 2:04 am
Hello.
I want to source the right turbo for my LD28, I think a T3/T04E might be a bit extreme for this low-mid boost application.
I would look to run 5-10psi atleast for a start.
It's a low RPM beast so maybe a <0.5 A/R turbine housing would suit??
What do the L20et's use as their stock turbo? Or RBdet's for that matter?
Any help would be appreciated.
I also fail to understand how a T3/T4 hybrid can be so powerful but a basic T3 or T4 not so much?
Thanks.
