Electric Fans
Electric Fans
Hi guys
After reading the article in the Technical section on the electric fans, and not learning anything new, i need to ask the question.
Currently i have 2 12" fans on the front of the radiator, yet the Z still heats up when idling or driving slowly, and the temperature creeps a bit high for comfort before the fans come on. The temp needle will normally sit about halfway up the guage when driving around, but the fans will not come on until the needle reaches the "M" in TEMP, which seems a bit high. I am replacing the current thermo fan switch with one of a slightly lower operating temperature shortly
Is anyone else running electric fans with more sucess? and secondly, what sort of temperature should the Z run at anyway. Halfway up the guage is about 125 farenheit, which is only about 50 celsius, and that seems really cold.
Any info would be appreciated
Zac
Zac
[M4VR1K]
1974 Datsun 260z 2+2
I think the thermostat for the 300ZX opens at somewhere between 75 and 80 deg C. Try putting your fans behind your radiator and see if the cooling ability improves, as I'm sure you will get better cooling.
Most people overestimate their electric fans ability to cool their motor and underspec their fans - I have found some extreme fans that flow previously unheard of CFM ratings, as listed below. I have heard than the standard 300ZX fan is good for 6000cfm, but I wonder what RPM is required to reach that - I'm sure the CFM of these fans would be enough to cool the radiator enough, as their RPM is not affected by the engine RPM
Zirgo (http://www.zirgo.com/)
3985cfm single 16" http://www.thehoffmangroup.com/Zirgo/de ... emid=ZFU16
3000cfm single 14" http://www.thehoffmangroup.com/Zirgo/de ... emid=ZFU14
These are my favorite brand of fans. Nice thing about them is every fan can be changed from a puller to a pusher without buying anything extra. The fans are also just fans, no fancy looks.
Flex-a-lite (http://www.flex-a-lite.com/)
3300cfm single 16" http://www.flex-a-lite.com/auto/html/18 ... treme.html (looks like crap)
5500cfm dual 15" http://www.flex-a-lite.com/auto/html/mo ... ctric.html
2500cfm dual 12" http://www.flex-a-lite.com/auto/html/lo ... ctric.html
Be Cool (http://www.becool.com/)
will update shortly when the bloody pdf downloads!
AKA ZFETSH
Now armed with a Z32 2+0 NA
Yep, because you may find the fans on the front are blocking air from getting though at speed
AKA ZFETSH
Some fans are designed as pull others as push - do you know what you have?
and did you turn the fan blades around? you may find the blades are curved and are specific to pulling air through
AKA ZFETSH
Most electric fans are the pull type and are mounted behind the raditor ie
front of car ----> raditor -----> electric fan ----> engine (the fast bit) ----> spinning wheels (the fun bit)
I would check the blades as Zfetch states.
ahhh, no, i didnt try that, ill whip them off tomorrow and see if they can be swapped over.
Unfortunately, wont be able to test the results for a few weeks, has been a holdup on the linkages for my new carbs, they have to come from England unfortunately.
Unless someone has a set of master linkages for Dellorto 40mm side draughts
[M4VR1K]
