Steering restoration
Hi,
Can anyone tell me what parts of my steering system I will need to replace/refurbish in order to make it good as new? Vehicle is my '72 240z.
Thanks.
Thanks.
All of the rubber parts help alot. The biggest difference I noticed was replacing the steering rack bushings. It felt like a new car. Go with the Poly bushings.
For a more direct feel, the squishy steering column coupler as well.
Check the ball joints for play, and the inner and outer tie rod ends
Get a WOF check and let them tell you.
Youre welcome, and nice car if thats yours in your Avatar.240tim wrote:Cheers, thanks guys.
On a related theme, my 1973 240Z was failed on a WoF yesterday with reason: 'Replace L/H rack arm (inner) due to excessive play'.
Can you sages out there provide guidance on what part(s) I need to source and suggestions on where from.
I *think* it's like this video: http://www.youtube.com/watch?v=e_dRAqYRbWI
(as opposed to replacing the tie rod end which I think is a lot simpler to fix)
My local garage said they had tried Nissan but no luck. I said I'd try you guys...
(I'm in Wellingtron)
Michael
1973 240Z (running)
1957 Austin A35 (in bits)
1973 240Z (running)
one of the rack ends is NLA it is the one with the LH Thread on it, I can't recall which side that is. Some of the earlier 240z inner rack ends can come apart so just need to be re-tightened - later items and 260z items are non serviceable so replacements are required.
The side that is available is like an arm and a leg from Nissan - but check ebay.com there is an aftermarket one you can get....I will see if I can find a link for you....
Here you go - this is the place I got mine from a while back
http://www.ebay.com/itm/Replacement-Tie ... 261wt_1163
Hi Michael.
Is your inner ball joint worn, or is the shaft/rack moving in the housing as in the pictures? You need to get an assistant to firmly wobble the wheel, while watching to determine what the problem is before going further.
If the movement is the same as the vid. you may be able to take out some of the movement if you undo the LARGE lock nut on the pinion housing and then tighten the large slotted screw.
From memory it is difficult to access with a large wrench.
If you look closely at this image you can see this is the non rebuildable item (well not without work aka HBI Engineering as Daniel has pointed out) you can see the weld towards the bottom of the rack end.
I believe early 240z items don't have this part welded tso it is possible to tighten them up. These later type can only come off the rack and get replacedb. But if a place like HBI Engineering can rebuild these great.
