Re: Datsun 280ZX IMSA GTU race car build...
Woo Hoo, excellent. What's your plan for running in, just on the dyno or something a bit more detailed?
Just on the dyno.
Hopefully it goes more or less first time... and then want to run it for say ~1 hour non-stop at 1500~2000 rpm to run the cam in.
Thats what Kameari recommended, I'll put a break in lube on the cam before startup.
We will also get oil pressure by turning over the dry sump pump before start up.
Will use some BP7ES plugs for the initial running in, and have some colder ones for when it gets more serious.
After the first hour I will do what the experts say...
Well its pretty much done.
A few under bonnet things being corrected, and some minor jobs being finished now.
So will get a wheel alignment next week fingers crossed, and then oil priming & water leak test before the big day!
- stevenewenham
Wow- exciting!
It's looking a million dollars!
Thanks Steve!
Yeh, very true... you need to start by digging a big hole, and when done, make it deeper.
Then prepare to fill it with $$$, until its full. And then you have a race car. Lol...
Yes, will share results as soon as i have them, be it good or bad or indifferent...
Even closer now.
Running in oil (Penrite 10tenths) added and pump primed and run so oil is everywhere but the cooler due to the oil thermostat.
Looks like it takes around 10L of oil!
Water added for now but will be drained out later and replaced with motorsport coolant/corrosion inhibiter.
New water thermostat housing top looks a bit odd, but works perfect
Power steering fluid (Redline) added.
Cables under dash tidied up and brake lines tightened.
Brake & clutch fluid (endless racing) added and all working!!!
Final tasks are:
Set ride height and do full wheel alignment to adjust front & rear camber/caster/toe...
Complete DBW relocation.
Ready for 'Start'!
Final tasks are:
Ready for 'Start'!
Ok, nearly as exciting as what the engine will produce... here is the weight of the car with all fluids and 20L of fuel:
1153 kg (2540 lb's)
I assume weight difference at the rear is due to the Dry-Sump oil tank being pretty much over the top of the LH rear wheel.
The front I guess is all down to the motor, as the ancillary items would not make much of a difference...
Also ride height is set, and alignment complete.
Next up Dyno time...
1153 kg (2540 lb's)
- stevenewenham
Were you sitting in it when weighed? If not that will swing the bias from left to right.
When you say alignment complete, did that include weight jacking , or is that still to come?
That is a light car, wdll done. Fun with I assume 250-300hp it should fly.
I too assume you (or driver ballast weight was not in it). Since you have all the adjustable suspension might be worth chasing cross weights with driver weight.
There is a good video on it here
https://youtu.be/jpuztcGQM9k?feature=shared
Not sure what it's called, but yes, alignment was undertaken by the Koni Racing Shock suspension guru, not just a 'wheel alignment' dude.stevenewenham wrote: ↑Thu Dec 07, 2023 10:33 am Were you sitting in it when weighed? If not that will swing the bias from left to right.
He had to keep the sway bar link removed from one side as he tested the set up etc.
Hi Mike, yeh my bum was not in the driver's seat.mikec(nz) wrote: ↑Thu Dec 07, 2023 4:12 pm That is a light car, wdll done. Fun with I assume 250-300hp it should fly.
But overall happy with the weight and balance so far.
As for power, will know in little over a week, it's booked for the 18th.
It should have a minimum of 300hp at the flywheel, any less and I'll be disappointed, anymore and I'll be grateful
The plan is to do that when I'm down their next time but looking at the numbers it's not far away with luck.
Dwane Bicknell of Bicknell Autosport & Engineering is doing it, he basically does a lot of the motorsport shocks in NZ (He does all of George Stock's work...).
- stevenewenham
We await the magic number with baited breath! I am sure not as baited as your breath!
Thanks Steve, only a few days to go... If it all goes quiet, don't ask...stevenewenham wrote: ↑Mon Dec 11, 2023 10:30 am We await the magic number with baited breath! I am sure not as baited as your breath!
