Hows this for a new ICE (Internal Combusion Engine) design. Will run Bio-Fuel as both the fuel, oil/lube and cooling (plus air cooling). a 14" by 14" motor is equilvalnt of a 850cu inch or 4xV8 engines and 2000HP. The plan is for an engine the size of a small paint tin will replace your engine and produce 250HP - what the?
Check it out. Angel Labs - The MYT™ (Massive Yet Tiny) Engine
