Intake Plenum
300ZX
82m
Intake Plenum
Post by 82m » Fri May 04, 2018 7:25 am
Has anyone ever tried putting the lower intake plenum from a z31 onto the z32?
Or know any reasons why it could not work? I realise the heads are different but how different?
85_z31
Post by 85_z31 » Fri May 04, 2018 1:42 pm
Hi Mate
I'm one of the few on here with a Modified Z31
The Difference in the lower intake manifolds is quite different so they wont bolt up, In theory it could be done with a thick enough adapter plate
I have been working in with DJZ on here to design a better performing plenum for a Z31.
There is quite a lot of Z31 Plenum Idea's on Z31performance.com and also the Z31online facebook groups. For something really nice its going to be a fabrication required type deal.
A lot of People use a Nissan Terrano v6 Plenum as a core to build an RB/ Supra style tapered plenum.
1985 Z31 Slicktop Turbo
fome dome
Post by fome dome » Thu May 17, 2018 12:03 pm
I am running an early vg30det inlet manifold a lot larger inlet ports but you can port match the inlets to match the inlet runners easy enough.
82m
Post by 82m » Fri May 18, 2018 7:16 am
Cheers mate. That looks exactly what im after. Is that in your z32?
fome dome
Post by fome dome » Sun May 20, 2018 10:15 am
Yea ill start a build thread up later.
Those Det motors are hard to find unfortunately.
Are you going turbo or NA?
