280zx and cracked radiators
240z, 260z, 280z
andy120
Post by andy120 » Sat Mar 03, 2018 10:39 am
Has anyone else had problems with cracked radiators? I suspect there's too much chassis flexing going on stress loading the radiator. If that's the case, has anyone converted to a rubber mounted modern like radiator.
Post by bernjean » Sat Mar 03, 2018 2:33 pm
Nope no problems my end, still running original radiator except upgraded to 3 row.
Post by djz » Sat Mar 03, 2018 6:47 pm
I've rubber mounted the Skyline radiator I'm using, but not because I was having problems with them cracking. Is it a road car?
connor_sutherland
Post by connor_sutherland » Mon Mar 05, 2018 12:04 pm
Ive rubber mounted an alloy S13 radiator into mine. Its a tight fit with maybe 5mm spare room in total side to side. Custom made a bracket for the bottom out of aluminium channel with some rubber grommets that i found lying round in the shed.
To mount the top i simply used some R32 radiator mounts i got from a wrecker.
You will need a new radiator hose to the top tank as the stock one is too short, from memory one from a 78 Hilux does the job, but just go to repco and see what they have that is slightly longer than the stock one.
Hope this helps.
andy120
Post by andy120 » Tue Mar 06, 2018 2:49 pm
Yes its a road car
Post by djz » Tue Mar 06, 2018 6:25 pm
Standard radiator hoses? Not the ones with metal springs in them?
andy120
Post by andy120 » Tue Mar 06, 2018 6:37 pm
standard.
