Just wanting to know who has upgraded there 240z dizzy in favour for the 280z/280zx E12-80 dizzy.
* Is there anything else required besides the dizzy if you are allready using an aftermarket coil?
* Is the base plate necacery to mount it on an L24?
Would really appreciate some of the guys that have gone down this rout to chime in.
240z distributor upgrade.
That sounds promising, did you need a different base plate for it?merlin wrote:I have used the 280zx E12-80 dizzy just wired it up and away I went. I think it produces a lot more bang but I can't back that up without a dyno. Some guys say the tacho does not work or the needle jumps around but mine was ok.
