Removing 350z interior door panel...
After the break-in left bits of my passenger window everywhere (including under the bonnet!) Im facing the task of removing the post window-fix shards that have dislodged themselves and annoyingly rattle every time a passenger enthusiastically closes the door (as you do when faced with your first ride shotgun in a Z)...
After trying to take the dash out of my last skyline I've found that, no matter how careful you are, if there's a clip or screw you didn't know about it can lead to frustrated 'motivation yanks' on said panel causing potentially damaging effects.
Hence the forum stab, anybody out there have a clue how to pull that decent sized plastic door card out of a 350z without buggering anything?
My other A to B is a Z
- old_datto_fan
You'll need to register across the pond to see the pdf, here's the link:
http://350z-uk.com/forum/viewtopic.php?f=35&t=30870
It's quite easy to remove once you know what to do.
I used these two guides (very easy to follow, no need to register):
http://liljerk.morpheus.net/350Z/front_speakers/
http://www.350z-tech.com/zwiki/Tutorial ... stallation
2002 Nissan Fairlady Z
z33_boy sold his Z a while back, rarely checks in currently, well until he gets a 370.wld350 wrote:i recently took mine off to get to my regulator motor, of my 350z, the motor stopped working, just a bit of crap built up but its fixed now. It's pretty easy once ya get started, How did you get on?
