300zx racecar
martysauce
Re: 300zx racecar
Post by martysauce » Sun Feb 24, 2019 3:18 pm
djz wrote: Sat Feb 23, 2019 6:37 pm Trying some concentric twisting?
yeah i herd it was a good idea so thought i'd give it a go
Post by djz » Sun Feb 24, 2019 5:40 pm
martysauce wrote: Sun Feb 24, 2019 3:18 pm
The guys at work do it, it's extremely time consuming and to do a full loom takes days of planning. Looks cool when it's done though.
martysauce
Post by martysauce » Mon Feb 25, 2019 10:07 pm
i won't be going anywhere near that full on ,im mainly doing it to stop the wire turning into a huge rats nest
martysauce
Post by martysauce » Thu Apr 25, 2019 8:06 am
If I were to try run my vg30dett engine out of the car with an ecu and engine loom, which wires would i need to run power to? I am going to try use a spare loom i have laying around while i build another. I have built a fuse/relay box so the power wires will be switched and fused.
Cheers guys
martysauce
Post by martysauce » Thu Apr 16, 2020 1:53 am
So I haven't posted in a while but a few things have changed and I have gotten a bit more done thanks to the lockdown. I bit the bullet and had an engine loom built so I don't need to worry about too much wiring. I have started to try and learn to tig aluminium and although I suck at the moment I am slowly getting better. I have decided to build alloy intake piping out of 2.5" alloy which I am nearly halfway through.
I have turned an oil cooler I had laying around into a heater core so I can defrost the windscreen and get rid of excess heat if necessary.
I am potentially able to buy greedy td05 18g turbos for very cheap which seem to be a near bolt-on, other than oil lines. I know they are WAY too big for the max of 500hp that I'd be dreaming of but does anyone know how laggy they would actually be? I might just buy them for if I decide to go bigger down the track.
I am nearly at a point where I can start the car so hopefully not too long till it is able to go to the track. I'll try post some photos if I get a chance
mikec(nz)
Post by mikec(nz) » Wed Apr 22, 2020 10:29 pm
I have not run these, but they are a old style turbo and I think they are big and laggy. Also don't you need the greedy or pentroof manifolds to go with then?
In my experience Not much point in going for big turbos, better to stick with the GT25 for 500hp and the GT28 for 600hp. You want your power coming in around 3500-4000 not 5000 like the TD05 or TD06, whether street or track.
Post by bernjean » Wed Apr 29, 2020 8:42 am
I agree with you, its best to have great usable power in the range that you would use the car, go for the smaller turbo, love that punch you get as the turbos come on power.
Post by BRONZEE » Thu Apr 30, 2020 10:12 am
Great to see a Z32 getting some love.
freykarts
Post by freykarts » Thu Aug 13, 2020 8:19 pm
would love that!
