Marrow's '79 280zx
Changing to an RB25 will also require a huge investment in wiring and a computer if you don't stick with the factory one.
Excluding the initial investment of buying the RB25 I would say you would be looking at a similar dollar figure either way but with the RB25 having more potential (in my opinion) than the L28 and a better selection of aftermarket parts.
The RB25 wouldn't really provide an easier solution to a manual conversion, if you are using the big RB25DET box it doesn't fit in the tunnel without cutting the mounting ears off so you have to make custom mounts.
Wiring yes, but I've seen a few rb25 frontends that come complete with loom and ecu. I'll probably look at getting a link or megasquirt anyway, because MS seems pretty interesting.djz wrote:Changing to an RB25 will also require a huge investment in wiring and a computer if you don't stick with the factory one.
Is there a better solution for gearboxes then? because trying to find a stock l28 5 speed box would be hard (not to mention old)
L series gearboxes are still out there, I sold one a few weeks ago. The other option if you are sticking with the L series is to use an L series bellhousing on the front of an later RB/CA/SR gearbox, but those are getting harder to find is good condition as well.
djz wrote: later RB/CA/SR gearbox, but those are getting harder to find is good condition as well.
Yup thats your option, good for 400hp some say. It's the box that is usually described on trademe as RB20DET and will both fit in the tunnel and straight onto your RB. (note most boxes on TM described as RB20DET are not!! Be careful)
So I could use an rb20/sr20 box for a simpler conversion if I get the l series bellhousing, or if I go the rb25det route, to get the rb20 box?Andy wrote:djz wrote: later RB/CA/SR gearbox, but those are getting harder to find is good condition as well.
I enquired with a parts importer about getting an RB25 and box, and they asked if I wanted an RB20 box or an RB26DETT box for it.
this is good to know.
Correct on both counts
L series engine use L series bellhousing modified for RB20de or RB20det box
RB engine use RB20de or RB20det box without modification
The lighter weight RB boxes are almost the same weight and dimensions as an L series box.
I looked at using the big box on our race car, was put off it by wiser people, and very happy with the RB20det box, have only broken a fifth gear once.
No point carrying extra weight around if you dont have to.
We drive Japanese vehicles because they are efficient designs, no point over engineering stuff, thats for the hot rodders and muscle car guys
I guess the question all comes back to how much hp you want and how fast you want to go
The gear box will give you fun either way and at the risk of upsetting the Auto fans out there, maybe a bit more performance as well, the L28 is a rock and will rev bog standard to 7000 and come back for more, give it a cam grind for peanuts and have a bit more fun, you wont wear it out or break it, then think about the RB
I do agree the std hp from the L28 wasn't earth shattering, but if you are restoring the interior, you may want under the bonnet to look original, unless you are building a sleeper
Pretty much... although I don't know if you can rightly call z cars sleepers, they already *look* fast, but stock, not a lot of fun. I don't have the budget for a true sleeper, but I'd love to combine classic jdm styling with modern tech under the hood.Greensheep wrote:unless you are building a sleeper
My specimen isn't really restoration material, but if I do an engine swap I'll probably keep the l28 in case I want to put it back in down the line (wouldn't want to kill any more of these endangered species).
Been pretty busy with it, working through the interior/exterior while I collect parts for the conversion.
Had my flywheel machined, new m/s cylinders, new clutch kit this week.
Does anybody have any wisdom on pulling the pedalbox out? I've taken out the dash, and as far as I can see I've removed the 4-5 nuts that should hold it on to the chassis/firewall.. but it doesn't seem to be coming out.
Should I be taking the pedals off before taking the box out? or just disconnecting the brake cylinder?
Ok, cheers I'll have another look. Otherwise got a mate coming in the weekend if it takes me that long.
Also I know i'll have to disconnect the brake master cylinder, but how about the accelerator/throttle 'pushrod'. There are no bolts to disconnect on it, so do you just need to pop off those little white plastic ball joints to remove the pedal?
(A pain that I can't disconnect all my wiring, because the alarm system has been hardwired, so to get it out of the way i'd need to cut and rejoin it. )
