Okay I see, I also bought billet adjustable lower arms from the states, didn't need the bump steer spacers as I repositioned the steering rack when I converted the car to power steering. Used a Subaru steering rack, was one of the best things I ever did. Gave me much less lock to lock, direct feel. Good sport set up.
...I have used a series 2 280zx rack&pinion power steer unit along with a steering reduction gearbox to make it very responsive, hopefully not to much.
QUESION: - BEST WHEEL STUDS to get?
Looks like i will need a wheel spacer on my front, probably 6mm (10mm absolutely maximum), as my gap between my spring and tyre is <5mm at the most.
[Ideally my front wheels should have been another 1/4~1/2" offset... too late now..., and I also need to get the actual tyres i intendon using to confirm...]
Was looking at ARP or NISMO brands...
I know ARP should be good, not sure if the Nismo studs are rebadged chinese made stuff...
Any opinions advice out there.
Thanks.
Thanks.
You can get these from Davie Motors at Manukau, you may have to get longer ones and cut them down.
http://www.niceproducts.com.au/catalogu ... /wheel.php
Body is blasted, and now etch primed, ready for the panel work to start.
Front cowl plate has been eaten with bora, so will need to find a replacement!
at the painters...
at the painters...
Cleaned and primed my steering rack, will top coat it this weekend weather permitting...
Also got new bushes from Ebay
New Brake Rotors now in the garage
Wallet suitably lighter...
New sills, new front cowl in progress, and other bits...
Car takes shape!
Car takes shape!
Steering rack before and after...
(Still need to powder coat the cross member)
The body takes shape...
- New sills & cowl in place,
- Roof in place,
- Front guards & head light bezzels on,
- Bonnet on,
- Passenger Door on (and it opens & closes!), drivers door in progress
- LH Rear quarter mostly on...
- Roof in place,
- Bonnet on,
Thanks for the motivation guys & gals, its always needed and welcome!
More plastic bits now on.
Next is the wing on the hatch...
Then its time to fix all the bits to prepare them for the paint... still a little while away...
FRONT AIR DAM:
Say good bye to those 5 little holes in the top of the air dam, also this part is going to be raised a little.
The light holes will be opened up a bit for brake ducting...
Other changes will be made as well, just not sure on the best method, basically after the front air dam to be about 25~50mm lower, and level with the ground...
Also the intermediate cross bar in the main air inlet may dissappear.
Any ideas, opinions wecome.
FRONT AIR DAM:
