From what I can gather:
- I need a Group 35 battery. Seems like that spec is to with dimensions of the battery and the location and size of the posts?
Minimum 490CCA for the 350Z and preferably a little higher?
Not more than 6 months from date of manufacture. There is a coded date marking on the battery indicating month and year of manufacture.
One with a high rating for deep cycle. Getting a little lost with this one!
Also looks like I might benefit from a trickle charger / conditioner to keep the battery charged up as the Z can sit around for a week or two. Apparently extends the life of the battery but need one that recognises full charge and cuts out. Any recommendations?
Any tips and tricks to swapping them over, or is it best to get the supplier to do that? Disconnect negative first. What happens to computer / alarms / electrics etc if they lose power when old battery is disconnected?
Thanks in advance.
