heavy duty clutch
300ZX
martysauce
heavy duty clutch
Post by martysauce » Fri Nov 07, 2014 10:40 pm
hey guys im looking at getting a new clutch my z32 is turbo but i think has a non turbo gearbox. my question is will a turbo clutch still fit and anyone got any clutch ideas, my z has around 400hp but im aiming for 550 cheers
Post by djz » Sat Nov 08, 2014 9:31 am
You will be nearing twin plate territory at that kind of power. If you want to try a single plate you'll need to figure out what flywheel is fitted if you have doubts about the gearbox.
martysauce
Post by martysauce » Sat Nov 08, 2014 10:26 am
iv been trying to find out if this twin plate clutch would work http://www.z1motorsports.com/product_in ... ts_id=4133 but they wont email back . what do you recon would ther be fitting issues if the gearbox is a non turbo one as far as i no it has a factory tt clutch. oh by the way i was talking to you a while ago about ecus i ended up getting a plug in z32 link from nz efi
mungyz
Post by mungyz » Sat Nov 08, 2014 10:28 am
If you have an NA gearbox it's no problem as you can remove a very small amount of material from inside the bellhousing and run a spacer on the starter motor and then run the TT sized flywheel & clutch.
A GOOD single plate clutch will hold up to 400KWs at the hubs no trouble at all - been there done that :wink:
Beware of southbend clucthes a lot of the Aussie guys have been having trouble with these & the responses from Southbend have been a little odd to say the least.
The ~$500 flywheels from Trademe work OK but will get hot spots & then harden in those ares making machining them after this very tricky - essentially a one time round flywheel it seems. (having said that you can use them again but it wont be a perfect situation).
The critical thing in holding the torque is the pressure plate & quality of the friction material, I've used an Extreme motorsport ressure plate in the past & found it to be pretty good with pressure on the foot but held up well to ~400rwkw when paired up with a six puck brass button type friction plate - not that hard to drive if you are good at ear,eye,foot coordination :wink:
martysauce
Post by martysauce » Sat Nov 08, 2014 10:40 am
haha ok im in a bit of a pickle i cant decide if i spend the money and get the twin plate http://www.z1motorsports.com/product_in ... ts_id=4133
or get the exedy http://www.trademe.co.nz/motors/car-par ... 676235.htm
or this other brand not sure what it is http://www.trademe.co.nz/motors/car-par ... 702081.htm.
what do you think thanks :D
mungyz
Post by mungyz » Sat Nov 08, 2014 10:57 am
The Z1 twin plate has some very good things but a couple of things you need to know:
Noise, it's not more or less silent like most OEM clutches, it will make a slight chirp when engaging & it will have a slight rattle while your foot is on the clutch pedal.
It will allow the engine to rev more freely but will also stall easier, the bite of the clutch is not what I would call "on or off" but it will give you some fun learning to drive with it :)
If the car is a fun car & not your daily drive then the Z1 twin plate is a cool bit of kit that works well, we have tested one to 500Kws at the hubs with no trouble, have one in my car & a third customer has one - all very happy with them.
If you wish to go with the Z1 clutch then consider getting in touch via PM as I can sort out a good deal on purchase price & shiping etc :D
As for the others I would go with Excedy long before the other brand even if the Excedy unit cost twice as much :wink:
