New gauge faces for 280zx
- reliablejunkie
Hey everyone, this week I have been doing some big things to the 280zx before i drive it up to the beach hop this weekend. One of which was change all the faces on my gauge cluster. I didn't want some aftermarket ones, just something that doesn't look so dated. I have attached some photos of what i finished today.
- I popped it all back into the cluster and this is the end result. What do you guys think? Not bad for $18 huh?
- 9.jpeg (99.01 KiB) Viewed 3193 times
- and in with the new.
- 7.jpeg (73.88 KiB) Viewed 3193 times
- Out with the old..
- 6.jpeg (129.42 KiB) Viewed 3193 times
- I lined up the transparency and regular paper and glued it together.
- 5.jpeg (69.12 KiB) Viewed 3193 times
- And the same again on regular paper.
- 4.jpeg (77.1 KiB) Viewed 3193 times
- I designed the new look i wanted in photoshop and had them printed out on transparency paper
- 3.jpeg (71.88 KiB) Viewed 3193 times
- This is the original cluster in my 280zx
- 1.jpeg (82.5 KiB) Viewed 3193 times
- reliablejunkie
sometimes it is just that easy I wanted the tacho to go to 8000 but i didn't want a big amount of redline so i shifted the yellow and red so it looked easy on the eye. the next step is to pull the engine out and make some changes so its true. I plan to be putting up a build thread of my own in the next 2 months.
