260Z clutch hydraulics
240z, 260z, 280z
stevenewenham
Post by stevenewenham » Tue Nov 23, 2021 11:41 am
Clutch pedal slowly got closer to the floor over a couple of weeks until unable to select 1st gear..
Master cylinder full so no fluid leaks..Bled the slave cylinder and was lots of air in there..After bleeding,
clutch was 100% again.Last weekend the same thing happened after about 30mins driving..I did notice the first time
that the master cylinder had a dirty tide mark around the top, along with some gunk in the filter at the bottom of the MC reservoir..
1.If the system is fluid tight, where is the air getting in?
2.What is the fix?
Slave was replaced 4.5yrs/15k K's ago and MC 3yrs/7k K's ago..
Any ideas ?
Post by bernjean » Mon Dec 06, 2021 8:47 pm
I would suggest that the air is getting in on one of the connections. Maybe tighten them all up a bit.
