I have decided to sell my set of 3 new OER brand Throttle Bodies - these bolt straight on to any triple carb inlet manifold for the L6 motor that is designed to take Weber, Dellorto or Mikuni side draught carbs.
Great enhancement if you want to use computer control for your engine.
I also have an inlet manifold and air box to suit and could be persuaded to sell these too.
See http://www.trademe.co.nz/Browse/Listing ... =234712238 or contact me via this forum.
L6 Throttle Bodies OER ITB
- old_datto_fan
I don't think they are tapered bore but if they are it is not really noticeable. I am away from home until Thursday so will check then for you.
Airbox probably could be sealed but not really designed for non-turbo applications.
Don't have any linkages sorry, I will check when I get back to see if any of the Weber linkages I have fit.
I haven't used them so hadn't got as far as working out how I was going to connect them up.
