L28
n42 head, f54 block
Comes with
New full gasket kit
New factory rear main seal and strip seals
New factory thermostat
New factory oil pressure switch
New valve stem seals
New pilot bush
2x distributors
EFI intake manifold (off different engine)
Looking for $500 for the lot
LD28 crank $250
LD28 gearbox bellhousing, fits on a F5W71C gearbox (has the larger shift rod hole) and bolts to L series engines. $50
F5W71C gearbox from S14, housings split to test fit above bellhousing, will need a new tail shaft bearing (as I removed it) so $100, nothing wrong with box beforehand that I know of.
Jeremy
